[phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 282: Undefined array key "app_rebranding_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 283: Undefined array key "app_url_scheme" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 284: Undefined array key "app_icon_url" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 285: Undefined array key "app_name" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 287: Undefined array key "app_alert_message" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 289: Undefined array key "app_android_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 290: Undefined array key "app_android_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 291: Undefined array key "app_banner_message_android" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 294: Undefined array key "app_ios_id" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 295: Undefined array key "app_ios_description" [phpBB Debug] PHP Warning: in file [ROOT]/ext/tapatalk/tapatalk/event/main_listener.php on line 296: Undefined array key "app_banner_message_ios" [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4150: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3035) Generadores de obra - Foros Ingeniería Civil
Tengo varias dudas, espero y me puedan ayudar.
La primera es que tengo que cuantificar y no se a que se refieren (según entiendo es el cálculo de los volumenes -concreto, tierra, etc-, y materiales que se requieren o se tienen).
La otra es sobre los generadores de obra (supongo que se refiere a lo que se va haciendo en obra)
y otra más es que al parecer hay unos formatos que se tienen que llenar y que por lo que me comentaron, son un poco más dificil los de acero, ya que según existen para cada tipo de material
Y a que se refieren cuando me indican que se tiene que cuantificar obra civil, especificamente que tengo que hacer.
A todo esto, en la escuela me enseñaron a calcular concreto, mortero, acero y madera, el problema se centra en que los terminos tecnicos no me los enseñaron y no se a que se refieren (generadores de obra, cuantificacion de obra civil, etc.).
Si alguien pudiera explicarme estos conceptos se lo agradeceria.
Gracias.
ok no te espantes todo lo que preguntas te aseguro que ya lo sabes solo que desconces sus tecnisismos.
cuando se refieren a cuantificar estas en lo correcto de sacar volumenes ya se de materiales o de algun trabajo en particular, por ejemplo:"excavacion de cepa por medios manuales en material tipo II. incluye: materiales, mano de obra herramienta etc, etc y se cuantifica por volumen (m3)
regularmete cuando te piden cuantificar se refieren a volumenes de matriales como pueden ser cemento, varilla, arena, grava, concreto, madera, etc,etc
hablando de generadores de obra tienes que tomar en cuenta que debe de existir un catalogo de conceptos que va a ser el que te guiara que es lo que debes de generar por ejemplo concreto, cimbra, excavacion, muro de block, etc. cada concepto va acompañado por su unidad de medicion como puede ser ml, m2, m3, lote, etc. toda esta informacion de volumenes se tiene que vaciar a un formato que se llama generador de obra. este formato no es mas que solo una hoja donde se detallan las operaciones aritmeticas con las cuales sacaste tus volumenes es decir largo x ancho x alto dependiendo cual es tu unidad de medida del concepto que estas generando. Normalmente donde trabajas ya cuentan con un formato de generador de obra. cabe aclara que en este formato tiene un espacio para agregar un croquis donde aparecen medidas y ubicacion de lo que estas generando (tambien lo puedes llamar generar) para asi poder respaldar tus volumenes. Ahora cuantificar acero tiene dos partes: una se refiere a varilla corrugada y el formato cambia ya que regularmente la varilla se cuantifica por kg. o ton. para esto nesecitas saber los pesos de la varilla por metro lineal como son #3 = .0557 kg/ml #4 = 0.996kg/ml etc. en este generador se encuentra una fila donde aparece el nuemro de la varilla y su peso por metro lineal entonces lo que haces es medir longitudinalmente tus varillas y multiplicarlas por su peso y con eso te da el peso del acero. Ojo hay que tener precuacion de ubicar correctamente las varillas por su diametro o de lo contrario tendras errores. la otra forma de generar acero es cuando hablamos de acero estructural como son angulos ipr monten placa canal "c" etc, estos de igual forma se cuantifican o genran por kg o ton en la pagina de villacero encuentras unas tablas donde viene los pesos de cada perfil por metro lineal solo existe una diferencia para generar placa ya que esta se cuantifica sacando el area y la multiplicas por su peso/m2 todos los demas perfiles se cuantifican igual que las varillas.
bueno cuando te hablan de cuantificar obra civil quieren decir o se refieren a todos aquellos trabajos llamados obra negra (excavaciones, cimientos, muros, losas, aplanados, etc) es decir todo lo que pueda hacer un maestro albañil a eso se refiere la obra civil (lo que no es obra civil son todo tipo de instalaciones como hidrosanitaria, electrica, acabados, jardineria,etc).
por ultimo para que no te enrredes tanto con los conceptos de "generar" y "cuantificar" te mecionan que se refieren a lo mismo (sacar volumenes) solo que el concepto de "generar se refiere a hacentarlo en el formato de generador de obra
SE ME OLVIDABA,
SI NECESITAS MAS AYUDA YO PUEDO FACILITARTE ALGUNOS FORMATOS DE NUEMROS GENERADORES TANTO PARA ACERO COMO PARA OBRA CIVIL SOLO PONTE EN CONTACTO POR EL BLOG, YO RECUERDO QUE BATALLE MUCHO CUANDO SALI DE LA ESCUELA CON LO MISMO Y ME DARIA MUCHO GUSTO PODER AYUDAR A QUIENES RECIEN GRESAN DE LA CARRERA
Gracias por la ayuda.
Si pudieras ser tan amable de un ejemplo te estaria agradecido, ya que lo que mencionas pues si lo he hecho pero mi problema sigue siendoi los formatos que se tienen que llenar ya que según yo lleno lod generadores pero estan mal. Así que si me pudieras facilitar un ejemplo te estaria muy agradecido.
Adjunto formatos para generar varillas, terracerias y un formato general.
La finalidad de los generadores es ser el soporte para el cobro de trabajos de obraa ya realizados (una vez que ya tienes adjudicada una obra). Tambien sirven para soportar las cantidades que integran algun presupuesto que presentamos a algun cliente.
Debes tener cuidado de si tu cliente te pide un formato en especial.
Saludos y espero los formatos les sean de utilidad.
HOLA, LA VERDAD QUISIERA APRENDER MAS SOBRE EL TEMA.
ESTOY EMPEZANDO A TRABAJAR, PRESISAMENTE ELABORANDO PRECIOS UNITARIOS; PERO NO ESTOY FAMILIARIZADA CON LOS TÉRMINOS.
APROVECHO PARA AGRADECERLES LA INFORMACIÓN Y OJALÁ PUDIERA ESTAR EN CONTACTO CON ALGUNO DE USTEDES PARA ACLARAR MUCHAS DUDAS CON RESPECTO A LOS GENERADORES DE OBRA.
DE ANTEMANO MUCHISIMAS GRACIAS Y HASTA PRONTO!!
Hola Mazing, concuerdo con los foreros sobre generar y cuantificar, un detalle que quiero hacer notar es que cuando generes aceros debes fijarte bien en lo que dice el concepto de tu catálogo, generalmente se incluyen en el precio ya cobrado los cortes, empalmes, dobleces y silletas de las varillas pero otras no, en el primer caso tu mides la longitud efectiva de una varilla en algun elemento y ya, con eso sacas su peso, pero no es raro que el concepto no te indica claramente que incluyas todas las "demasías" así es que podrías cobrar los dobleces y silletas y es una cantidad apreciable, seguramente eso te llevará a tener que revisar con el cliente como cobraste un acero o que incluiste y no se trata de cobrarle de más pero si de recuperar lo no especificado en el concepto y que en la realidad se ejecuta. Espero no haberte enredado más.... en realidad no es complicado, es talacha pero nada más. Un saludo
LUYLUX escribió:HOLA, LA VERDAD QUISIERA APRENDER MAS SOBRE EL TEMA.
Hola LuyLux, en lo que pueda ayudarte en PU. Un saludo de Toluca, Mex
hola buenos dias,mucho te agradecere si me puedes apoyar con los formatos de obra que tienes, ya que los mio los perdi accidentalmente, te agradezco tu apoyo, gracias
acabo de entrar a trabajar en una constructora y me gustaria aprender a hacer estimaciones pero no se como sacar los numeros generadores no se si me pudieran mandar un ejemplo sencillo.
podria ser de pavimento o revestimiento por ejemplo
gracias
disculpen, yo soy alumno de ing civil y estoy eleaborando un proyecto de construccion desde cero, solo basado en los planos de ay tengo que sacar el catalogo de conceptos y formular los generadores, la cuestion es.....habra alguien en el foro que me quiera ayudar y proporcionar un proyecto terminado de una casa habitacion con todo lo anterior mencionado, este es solo para tomarlo de referencia..... gracias!!!
Hola Luylux el asunto de los generadores de obra es simple mas que nada es cuesrtion de sentido comun y claro de revisar el presupuesto con el cual de haya concursado o asignado la obra.
es importante que reconozcas dos aspectos.
el primero el concepto que estas generando . ejemplo generar una excavacion debe dd ser acorde al concepto que se contemplo en el generador asi pues no es lo mismo generar una excavacion en cepa (misma que regularmente se cobra por metro lineal ml) que generar una excavacion a cielo abierto (misma que se cobra por metro cubico m3.)
el segundo punto a considerar es la unidad de medida con la cual deseas generar (esta debe de ser la misma que en el presupuesto) segun el ejemplo anterior las excavaciones regularmente se generan en metros cubicos (m3), al igual que la mayoria de conceptos que impliquen volumenes... concreto, agua, gases, etc. la cimbra en metros cuadrados, pintura en metros cuadrados (m2) asi como cualquier concepto que se traduzca en areas. y por lo general generas en metros lineales (ml) conceptos muy especificos como algunas cintillas de acabado. materiales de instalaciones como tuberias y cableados.
Por ultimo un generador debe de contar con informacion basica muy importante.
1.- el concepto que estas generando
2.- la ubicacion de los trabajos realizados o generados (ubicacion dentro del proyecto mediante ejes de plano, niveles, y en su caso cuerpo del proyecto. asi como nombre y ubicacion del proyecto. (obra).
3.- en caso necesario un croquis por cada area generada (en caso de ser varios casos iguales repetidos puedes utilizar el mismo croquis) croquis de medidas lo mas explicito piosible (recuerda que los generadores son el medio de indicarle e informarle a personas no ingenieros o arquitectos que es lo que se esta o se pretende cobrar (base para las estimaciones), por lo cual tus croquis deben de ser entendibles hasta por niños chiquitos.
4.- los generadores deben de incluir asi mismo las operaciones realizadas para obtener los volumenes o cantidades de obra generados.. ejemplo en pintura utilizarias algo como... base * altura * numero de muros.= metros cuadrados de pintura.
5.- por ultimo es recomendable anexar un resumen donde se establezcan los conceptos generados y sus cantidades totales para elaborar los formatos de cobro de forma mas rapida. (estimaciones).
6.- por ultimo es recomendable que los generadores contengan los nombres de las personas que.. los calcularon (quien lo elaboro) reponsable de verificacion (quien los reviso) y responsanble de area o proyecto (quien autoriza el pago). asi como las frimas y fechas en que cada uno de ellos interactuo con ellos.
Sin mas por el momento espero la informacion te sea de utilidad y quedo a tus ordenes para cualquier comentario.
gracias
Hola bellota recientemente envie una respuesta acerca de numeros generadores. como mencione en ese post. realizar los numeros generadores suele ser mas una cuestion de talacha que otra cosa.
revisando la informacion encontre un tema interesante que menciona mazing30 y es la diferencia entre generar y cuantificar.
Asi pues generar u obtener numeros generadores se refiere a elaborar las cantidades de obra ejecutadas mismas que se presentaran a cobro.
por otro lado cuantificar se refiere unicamente a elaborar los numeros con los cuales se pretende realizar la obra.
es importante mencionar lo anterior ya que la cuantificacion de obra, se realiza via proyecto (planos) y se da por sentado que esas seran las cantidades a ejecutar. por otro lado los numeros generadors se obtnienen de la medicion de las areas o volumenes de obra ejecutados realmente esto es lo que se construyo y cabe precisar que la mayoria de las veces .. debido a cambios de proyecto o a otros factores.. los volumenes ejecutados son diferentes.
asimismo creo importante mencionarte nuevamente que los numeros generadores de obra dependen en gran medida del concepto y de la medida utilizada para cobrarlos m3, m2, ml, kilo, tonelada. pieza, lote, jornal, etc etc.
Sin mas or el momento quedo a tus ordenes para cualquier asunto relacionado que se te ofrezca.
Javiermioland
hola tambien al igual que todos mis amigos posteadores yo tambien ando no tan perdido en como generar obra pero quisera me ayudaran y me mandaran a pre visualizar como se ahce esto de los generadores y sus valores como lo son ml,m2,m3 etc etc
en el trabajo mañana voy ah realizar un levantamiento para despues generar lo del levantameinto espero me puedan ir ayudando........ vale gracias
racato_dj escribió:hola
soy estudiante y me gustaria ke me ayudaras con los formatos de numeros de generadores de verdad me serian de muchisima utilidad gracias.
SALUDOS
HOLA_COMPAÑEROS _ ME PARECE MUY BIEN QUE SE FACILITEN LA IMFORMACION QUE ES MUY ESENCIAL EN EL AREA DE TRABAJO_ LLEVO TRES AÑOS HACIENDO GENERADORES DE OBRA_ EN ALGUNAS CONTRATOS QUE HEMOS REALIZADO EN REFINERIAS_QUE CREO QUE LES VA HACER DE MUCHA UTULIDAD_ ANEXANDO_ MAS NUMEROS DE GENERADORES DE OBRA MECANICA, ELECTRICA E INTRUMENTACION_ SALUDOS
SALUDOS
HOLA _ COMPAÑERO_ ES LA PRIMERA VEZ QUE ME REGISTRO A ESTA PAGINA_ TE PUEDO FACILITAR ALGUNOS DE MIS NUMEROS DE GENERADORES_ QUE HE REALIZADO EN ALGUNAS OBRAS_ DAME UN TIEMPO EN ARCHIVARLOS_ Y TE LOS PASO_ SALUDOS
hola, alguien puede ayudarme tengo un nuevo trabajo y estoy algo desesperada, en mi trabajo se hacen estimaciones de obras, pero realmente no le entiendo mucho, a mijefe le llegan generadores o costeos de estos documentos tengo que realizar algunos formatos como generador de obra, estimacion de obra, control de asignaciones y un cuadre de maeriales, a todo esto se le agregan algunos formatos mas que envian como el cuadre de materiales y otros, el problema es que aveces los trabajos no se cobran al 100 porciento hay en algunos trabajos primera estimacion o hasta segunda estimacion segun sea el caso. alguien puede asesorarme porfavor no qiero perder mi trabajo.
mira luci, se requiere conocer un poco de obra, para realizar generadores, y en la mayoria de los casos las hojas ya estan vinculadas, solo es cuestion de meter los datos que te manda el residente. necesitamos ver tus hojas para ver como podemos ayudarte.
ok
hola disculpen alguien me puede facilitar algun catalago de conceptos de ( domo, techumbre o techo ) de una cancha de usos multiples, se lo voy a agradecer mucho . saludos
Disculpen alguien puede ayudarme a pasarme formatos de generadores de obra y explicarme como se debe de hacer un generador de obra de excavacion y tambien si me pueden explicar como hacer una estimacion por favor se los agradeceria mucho y si pueden mandarme formatos se losagradeceria mas gracias
racato_dj escribió:SE ME OLVIDABA,
SALUDOS
Hola que tal soy nuevo en la construccion y no tengo basta experiencia, pero como se ve que estas dispuesto a ayudar a los principiante quisiera saber como elaborar desde un inicio un generador de obra. por favor. Te agradeceria tu ayuda.
Hola espero se encuentren bien aaqui me encuentro buscando una ayuda valiosa que me puedan ofrecer, por lo que veo todos hemos pasado por lo mismo ojalá y puedan ayudarme estoy algo desesperado ya que mis generadores no logro realizarlos como se deben, ojalá y puedan proporcionarme uno de ejemplo les envio mi direccion eléctronica rofelo77@hotmail.com espero respuesta satidsafactoria.
genial que bueno contar con una sociedad para apoyarnos, yo igual paso por lo mismo espero y alguien pueda pasarme los formatos de generadores saludos!!!
orale que buena info y k buena onda de todos en el foro por proporcionar mas informacion sobre esto de los numeros generadores y los formatos que algunos anexaron, yo encontre esta informacion navegando por internet y espero k igual como para kien publico el tema como para los muchos otros k abemos recien egresados nos sirva para tener un panorama un poco mas amplio de lo k c trata esto de los numeros generadores.
1.- El número generador, parte de un proyecto ejecutivo así que tú obtienes del proyectista:
a)Un plano o juegos de planos donde se trazan las especificaciones generales.
b) Una memoria de cálculo,donde te indica el proyectista qué proceso siguió para llegar al proyecto ejecutivo definitivo.
2.- El presupuesto o contrato de obra consiste en la descripción de los conceptos o partidas necesarias para llevar a cabo la obra. (catálogo de conceptos), y su precio unitario correspondiente.
Ambos requieren de un análisis independiente y que llevan una secuencia lógica para el desarrollo constructivo del proyecto. los anteriores análisis requieren para su complemento el volumen de obra a ejecutar.
Aquí es donde entran los números generadores.
3.- El número generador, se obtendrá pues de los volúmenes geométricos físicos de obra a ejecutar, se obtienen del proyecto: aquí es donde empieza el trabajo de a "pie". Pero precisamente, no te la compliques, basta con que tengas el catálogo de conceptos bien definido y busques en el proyecto la geometría física que requiere para su construcción; así si te dicen: trazo y nivelación y la unidad de el precio unitario es el m2 sólo deberás calcular el área, de lo que te indica, y así con todos los conceptos; si te dicen en el concepto; excavación de zapata, y la unidad del precio unitario es m3, pues calcularás el volumen de la excavación.
Así seguirás con todo, sólo toma atención en la descricpción del concepto (pues tendrás que aplicar factores que conoces de las propiedades de los materiales , tales como factores de abundamiento, desperdicios, densidades, etc.),y la unidad del precio unitario: ml,m2,m3.
y lo demás es geometría pura.
4.- Cómo hacerlo:
a) tu plano desplegado ya sea en papel o en pantalla.
b) tu catálogo de conceptos ya sea en papel o en pantalla..
c) vas tomando concepto por concepto y lo analizas para obtener la dimensión física que implicará construirlo.
Consejo: como muchos valores dependen uno de el otro en secuencia lógica de construcción, si lo haces,combinando herramientas se te agilizará el trabajo, esto es..... pon un monitor extendido a tu pc, donde abrirás el plano , en la pantalla principal abre tu hoja de excel con el catálogo de conceptos y precio unitario.
Abre otro excel donde pondrás por renglones y columnas relacionado el concepto de el catálogo y sus dimensiones descritas: largo, ancho, profundo (o alto ). peso, densidad, etc. los factores que intervengan en su dimensión. ESTOS SON LOS NÚMEROS GENERADORES.
Dale sus valores y efectúa las fórmulas correspondientes que operen el excel. Relaciona el resultado de la página de generadores con la del concepto del catálogo y , paso por paso irás obteniendo tanto el número generador como el presupuesto.
Realmente es sencillo, sólo que hay que realizarlo con cuidado pues de esto depende el $$$$$ correcto de la obra.
El número generador tiene otra intervención en la obra y no menos importante, pues el anterior se obtuvo de un proyecto, sin realizar, así que todo está en papel, o digital pues, a según: pero cuendo la obra ya ha sido ejecutada, se deben de generar en obra las revisiones físicas de la misma , para presentar el generador de obra ejecutada, que puede ser igual al proyectado , pero suele tener variaciones a más o menos, y esto se debe controlar para el cobro de la misma.
Acá entra el concepto de "contrato de obra a precio alzado".
y es donde toma relevancia esto de los números generadores, pues de su cuidadosa elaboración en el presupuesto, depende la coincidencia con la obra ejecutada en la realidad. Si la obra es contratada a precio alzado normalmente será un gran conflicto variar a cantidades mayores los importes presupuestados.
y aclaro esta info no es mia yo la encontre navegando por internet asi k gracias tambien a kien publico esto en un principio
ORALE, SOY NUEVA EN ESTE FORO, LA VERDAD ME ENCANTO, ESTÁ SUPER INTERESANTE... COMO A MUCHOS LO QUE MAS SE ME COMPLICAN SON LAS ESTIMACIONES, LA VERDAD AGRADEZCO QUE EXISTA ESTE TIPO DE FORO PUES ES DE MUCHA AYUDA. LA VERDAD ESPERO APRENDER MUCHO MAS DE TODO ESO.
Hola pues los generadores de obra son la interpretacion grafica de los trabajos que estas ejecutando y pues son netamente el respaldo y comprobacion de tus trabajos son un soporte de la obra
Despues la estimacion es la conjuncion de los generadores de obra dependiendo el contrato si es estimacion por mes por dos meses depende del contrato
Si gustan y me pasan algun link donde subir un sistema que hace todo esto de la obra pues se los paso para que lo prueben
hola espero q me puedas ayudar con los conceptos y generadores de obra ya que aun estoy estudiando y no tengo muy claro; espero me puedas facilitar un ejemplo de una casa-habitacion, gracias de antemano, saludos desde guerrero
racato_dj escribió:ok no te espantes todo lo que preguntas te aseguro que ya lo sabes solo que desconces sus tecnisismos.
hola me podrias pasar los archivos x favor
es k no le entiendo a la cuantificacion si mme podrias ayudar en eso
[quote="racato_dj"] hola racato disculpa k te moleste pero me podrias facilitar lo de cuantificacion estoy en una construccion de obra civil pero no se komo se hace la cuantificacion y si me podrias pasar tu correo x favor
Tengo una duda con respecto a los generadores de obra, esto fue por una platica que se dio mientras se revisaban algunos de estos generadores. Comentaron algo sobre un "codigo de colores", se refiere a lo siguiente, por ejemplo, si se utiliza el color rojo significaba de correcion del valor; si era azul, se hacia referencia a que valor en el generador cambia a otro valor mayor o menor, etc. He buscado por la red y solo encuentro el "codigo de colores normalizado", este mismo hace la referencia a instalaciones sanitarias, electricas, gas y agua potable. O tambien se refieren para remarcar una zona de riesgo.
Estas clasificacicones de normativa de colores no es lo que busco, lo que necesito es el significado del color al momento de corregir un generador de obra.
De ante mano un agradecimeinto y espero sus comentarios.
AGEVEAS2011 escribió:Hola espero se encuentren bien aaqui me encuentro buscando una ayuda valiosa que me puedan ofrecer, por lo que veo todos hemos pasado por lo mismo ojalá y puedan ayudarme estoy algo desesperado ya que mis generadores no logro realizarlos como se deben, ojalá y puedan proporcionarme uno de ejemplo les envio mi direccion eléctronica arq.albertosalas@gmail.com espero respuesta satidsafactoria.
SALUDOS
hola soy alumno de ing civil. es varias ocasiones he encontrado trabajos que pides saber generar y sacar estimaciones. se que generar se refiere a volumnes pero pues se me complica he incluso tengo un poco de inseguridad. me podrias explicar que es y como se hace?? gracias
danielitoo escribió:hola disculpen alguien me puede facilitar algun catalago de conceptos de ( domo, techumbre o techo ) de una cancha de usos multiples, se lo voy a agradecer mucho . saludos
Que tal me pregunto si tubiste suerte con el catalogo de conceptos para la techumbre ya que actualmente me encuentor realizando un proyecto de ese tipo y me seria de mucha utilidad el catalogo.. agradeceria mucho si pudieses facilitarmelo a alberto_late@hotmail.com ...
HOLA , PRIMERO QUE NADA DOY LAS GRACIAS QUE HAY GENTE QUE COMPARTE SUS CONOCIMIENTOS , YA QUE ACTUALMENTE ES RARO , MI PROBLEMA SOBRE TODO ES LOS CONCEPTOS Y LOS TERMINOS , SI ENTIENDO LA LOGICA DE COMO SACAR LOS GENERADORES Y DE LA INGENIERIA DE COSTOS PERO COMO EN UN PRINCIPIO ESTUVE TRABAJANDO EN PUESTOS ADMINISTRATIVOS , NO TENGO LA EXPERIENCIA Y ME FALLA MUCHO EL CATALOGO DE CONCEPTOS DE LOS DIFERENTES PROCESOS CONTRUCTIVOS , OJALA ALGUIEN ME PUEDA AYUDAR
Pues leyendo todos los comentarios...resulta que me salen mas duas con respecto a la famosa cuantificacion, de hecho ya he realizado cosas de este tipo pero mas sencillas, por ejemplo de pintura de 2 proyectos, las dudas viene para saber como cuantificar materiales por ejemplo, varilla, cemento, arena grava....he descargado las tablitas que algun compañero subio pero quisiera un ejemplo grafico....vaya algo asi como un ABC
puesto que no es lo mismo ver teoria y aprendertela como perico a ya poner en practica todo lo aprendido en un proyecto real, es donde salen dudass....yo se q se presta a fusil si alguien sube alguna cuantificacion
Por cierto si alguien sabe de cursos de administracion de obra en alguna escuela o parecido, se agradecera la informacion, digo para tomarlo y que sirva de repaso
controldeobra escribió:Hola pues los generadores de obra son la interpretacion grafica de los trabajos que estas ejecutando y pues son netamente el respaldo y comprobacion de tus trabajos son un soporte de la obra
Saludos desde Mexico
SI LES AYUDA ESTE COMENTARIO, den las gracias, sino sigan adelante:
Tengan cuidado: Al elaborar sus generadores de obra, así evitan malos entendidos o creer que ya la hicieron $$$., Por eso vivales, ya abundan los que pagan a precio alzado.
Tener presente:
Los generadores de obra, solo son un respaldo para el pago, Pero se paga lo que es medible (por lo general los volumes indicados en los planos), Si tu hiciste trabajos de mas es tu bronca.
No olvidar:
Las cantidades de desperdicios en concreto, habilitado de varilla o abundamientos en excavaciones o acarreos y un largo ect., deben agregarse al precio directo, NUNCA a las cantidades ejecutadas en tu generador de obra.
El patron dice y que no se olvide: Yo pago lo que es medible.
hola me aprecio muy interesante el foro es la primera ves que lo veo y me salio navegando en internet buscando ejemplos de generadores de obra, creo que todos tenemos el mismo problema al termino de nuestra carrera, les agradeceria mucho que alguien me pudriera mandar un ejemplo de un generador de obra de cualquier obra para poderme guiar y en si ver en que consiste y todo eso..se los agradeceria muchoo GRACIAS!..
VAAVSA escribió:HOLA_COMPAÑEROS _ ME PARECE MUY BIEN QUE SE FACILITEN LA IMFORMACION QUE ES MUY ESENCIAL EN EL AREA DE TRABAJO_ LLEVO TRES AÑOS HACIENDO GENERADORES DE OBRA_ EN ALGUNAS CONTRATOS QUE HEMOS REALIZADO EN REFINERIAS_QUE CREO QUE LES VA HACER DE MUCHA UTULIDAD_ ANEXANDO_ MAS NUMEROS DE GENERADORES DE OBRA MECANICA, ELECTRICA E INTRUMENTACION_ SALUDOS
hola soy nuevo en esto estoy en terminacion de mi carrera de ing civil..y me encataria que me pudieras aportar un ejemplo de un generador de obra para tener una dia de como se cuantifica cada cosa..ojala y me puedas ayudar mi correo es reynaldo_nan@hotmail.com gracias!
hola!!!!
acabo de entrar a trabajar a una constructora y tengo q hacer generadores de muros de block y el acero para cimentacion y los castillos y todo eso. bueno mi priner pregunta para los muros se tiene que considerar de alto tambien el alto de la zapata? porq ps segun yo ahi tambien hay blocks.
otra pregunta bueno mas bien favor es si me pueden enviar ejemplos de como cuantificar el acero osea con dibujos o una explicacion o algo asi.
los formatos ya los tengo me los dieron en el trabajo pero me confundo mucho cuando tengo q sacar cuanta varilla necesito por eso de los dobleces los estribos ganchos y cosas asi. si me pudieran ayudar se los agradeceria muchiisiiimo.
mi correo es di_vina_112@hotmail.com o los anexas aqui para q otras personas tambien los puedan ver =) graciasss
hola tengo una duda sobre como hacer generadores de una estructura de acero y no tengo ningun formato a la mano si uds pudieran orientarme a como se hace se los agradeceria mucho porque me urge saber.
SALUDOS
Hola, soy nuevo me llamo antonio, recien sali de la carrera, si pudieras ayudarme seria de gran ayuda, ya que en los trabajos me piden sacar generadores, estimaciones, control de obra, y pues si se a que se refiere, pero tengo problemas al aplicarlos, si pudieras ayudarme con formatos, etc, seria de gran ayda, gracias mi coprreo viajero69_2@hotmail.com
Necesito ayuda para cuantificar material en estructura metalica para anuncios, si alguien me pudiera facilitar un formato para cuantificar el material, asi como los pesos por apoyos, que ando algo perdido.
Buen día compañeros, soy nueva en el foro... jeje; verán, comenzaré a trabajar en una constructora, y esta por empezar una obra de pavimentación, drenaje y red de agua potable, mi trabajo será hacer los generadores de obra... pero en mis clases donde hicimos algunos, no hice ninguna ejemplo de pavimentación o de redes, ¿tendrán ustedes algún formado para este tipo de obra?, mi jefe me dijo que el me daría el formato... pero igual me gustaría revisar otros antes para sentirme más segura, ya que es mi primer trabajo. ¡Muchas gracias de antemano!
