Elden Ring's Nightreign expansion has introduced some of the most intriguing new classes, weapons, and mechanics yet, and the Nightreign Scholar is no exception. Designed for players who enjoy a hybrid of intelligence Elden Ring Runes and dexterity with a focus on precise spellcasting and tactical weapon use, the Scholar has quickly become a fan favorite in both PvE and PvP. This guide will break down everything you need to know about the Nightreign Scholar, including stats, abilities, optimal relics, weapons, and the most effective builds.
Nightreign Scholar Overview
The Nightreign Scholar excels in versatility, combining potent sorcery with melee capabilities. Unlike pure mages who rely solely on intelligence, or dex-focused fighters who struggle against magical threats, the Scholar strikes a balance that allows for flexibility in combat. Their playstyle is particularly effective for players who enjoy adaptive combat: freezing, staggering, and debuffing enemies before delivering critical melee strikes.
The class also has access to unique Nightreign abilities that manipulate time and space in battle, making it an excellent choice for players who want to control the flow of fights.
Recommended Stats
Building a Nightreign Scholar requires careful stat allocation. The class naturally benefits from Intelligence and Dexterity, with secondary emphasis on Endurance and Mind. Here's a breakdown of optimal stats for early to mid-game:
Vigor: 20–25
Ensures survivability in both PvE and PvP, especially against heavy-hitting bosses.
Mind: 18–22
Supports a larger FP pool for continuous casting of Scholar ****** without frequent flasks.
Endurance: 15–20
Balances stamina for dodging, rolling, and weapon swings.
Strength: 12–14
Only needed if you plan to wield heavier melee options; most builds focus on dex-based weapons.
Dexterity: 25–30
Maximizes damage output for Scholar weapons, particularly those that scale with dexterity.
Intelligence: 40+
The primary stat, directly boosting ****** damage and increasing the effectiveness of Nightreign-exclusive abilities.
Faith & Arcane: Minimal *****
These stats are generally unnecessary unless you want hybrid support ****** or item discovery bonuses.
This stat allocation ensures the Nightreign Scholar can engage in mid-range combat while maintaining strong magical offense.
Abilities
The Nightreign Scholar comes with several class-exclusive abilities that make them a tactical powerhouse:
Eclipse Bolt -A projectile attack that temporarily slows enemies and increases stagger potential. Useful for controlling crowds and interrupting boss patterns.
Time Warp -Slows down enemies within a small radius for a few seconds, allowing Scholars to reposition or unleash combos. This ability is especially powerful in PvP against faster opponents.
Nightreign Aura -Passively increases ****** damage at low HP, rewarding aggressive play. Combined with quick dodges, this allows the Scholar to punish enemies while maintaining survivability.
Astral Step -A teleport-like maneuver that can pass through obstacles, granting the Scholar mobility in tight spaces and unique approaches to combat encounters.
Arcane Infusion -Temporarily imbues melee attacks with magic damage scaling from intelligence, letting the Scholar effectively blend ranged magic and melee bursts.
Mastering these abilities is key to the class's signature “hit-and-reposition" style, which rewards patience and timing over raw aggression.
Recommended Weapons
Nightreign Scholars thrive with dexterity-scaling weapons that either complement their spellcasting or synergize with their abilities:
Glacial Fang -A dex-based katana that adds frost damage to attacks. Its special skill can freeze opponents for a brief duration, making it an excellent combo with Eclipse Bolt.
Moonlit Staff -This staff scales heavily with intelligence, boosting sorcery damage. Ideal for primary spellcasting while keeping a melee weapon as backup.
Shadow Dagger -A fast, dexterity-focused dagger that allows quick strikes between ****** casts. Perfect for interrupting enemies or finishing off staggered targets.
Nightreign's Edge (Relic Weapon) -A unique sword exclusive to this class. It scales with both intelligence and dexterity, deals bonus damage to enemies under debuffs, and has a skill that generates a temporary area of slowed time, allowing combo-heavy playstyles.
Relic Recommendations
The Nightreign Scholar's relic options focus on increasing magic damage, mobility, and defensive options:
Eclipse Medallion -Boosts ****** potency and reduces FP cost for Nightreign abilities. Essential for prolonged engagements.
Chrono Talisman -Enhances Time Warp's effect radius and duration, giving Scholars more control over battlefield pacing.
Scholar's Ring -Increases dexterity scaling on weapons and provides a minor boost to intelligence. It's a balanced option for mixed combat builds.
Nightreign's Mantle -Passive bonus to stagger resistance when under 50% health, making aggressive tactics safer.
Combining these relics allows the Nightreign Scholar to maintain high damage output while controlling fights with superior mobility and tactical advantages.
Build Strategy
The optimal Nightreign Scholar build focuses on a fluid rotation of debuffs, crowd control, and melee bursts. Here's a recommended playstyle:
Initiate with Time Warp to slow enemies, giving room to cast Eclipse Bolt or position yourself strategically.
Debuff and stagger with Nightreign's Edge or Glacial Fang, exploiting the slowed state for maximum damage.
Switch to ranged spellcasting for priority targets or enemies that are difficult to approach.
Use Astral Step for repositioning, avoiding enemy attacks or creating openings for follow-up combos.
Activate Nightreign Aura at low health for high-risk, high-reward damage spikes.
In PvP, the combination of time manipulation, mobility, and ******-melee hybrid attacks makes the Scholar highly unpredictable. In PvE, the build excels at stagger-heavy bosses and groups of mid-tier enemies.
Conclusion
The Nightreign Scholar is one of the most versatile and mechanically satisfying classes in Elden Ring: Nightreign. With the right combination of intelligence, dexterity, weapons, and relics, this class offers unmatched control over both solo and group encounters. Whether you're freezing entire rooms of enemies or teleporting behind bosses for critical melee strikes, the Scholar is designed to reward tactical thinking, timing, and precise execution. Players seeking a hybrid caster-melee playstyle that thrives in flexibility Elden Ring Items and efficiency will find the Nightreign Scholar an indispensable addition to their Elden Ring arsenal.
MMOEXP-Elden Ring Nightreign Scholar Guide: From Stats to Endgame Setup
