If you've been hunting high-tier loot and endgame rewards, you've likely come across Purified Essences in ****** 4. These rare drops-associated with Andariel, Duriel, Belial, and Azmodan-are highly coveted by players, both for crafting powerful builds and for spam in-game currency. While many assume obtaining them is pure RNG (random chance), recent testing has revealed strategies to significantly increase your chances of acquiring these essences quickly.
In this guide, I'll break down everything you need to know about farming these coveted items efficiently.
Understanding Purified vs. Corrupted Essences
Before diving into farming strategies, it's crucial to understand the mechanics of Corrupted Essences and how they relate to Purified Essences.
Every lesser evil (Andariel, Duriel, Belial, Azmodan) drops a corrupted essence. You can carry a limited number at once-usually capped at 20. Once you reach the cap, you cannot stash, sell, or destroy them; your only option is to consume them.
For Andariel, Belial, and Duriel, this is straightforward. Head to Azmodan at Hawezar and open the chest tied to each lesser evil after Azmodan has been defeated. Each chest consumes five corrupted essences, freeing up space for farming more.
Alternatively, you can avoid picking up corrupted essences entirely. While it's theoretically possible to get Purified Essences at max cap, testing has shown that never reaching the cap massively increases drop chances.
Tip 1: Never Carry Purified Essences
It might sound counterintuitive, but holding onto Purified Essences reduces your chances of getting additional drops.
Instead, once you acquire an essence, immediately take it to one of the four altars scattered across the open world, each associated with a lesser evil. Offering your essence at the altar activates it, which also contributes to unlocking secret portals later in the process.
Remember, the order in which you activate the altars does not matter. Once all four altars are active, a red portal will appear, marking your progression.
If you need the locations of the altars, there are many guides available online, including video walkthroughs that pinpoint them accurately.
Tip 2: Enable Cross-Network Play
Contrary to some advice you may have heard, enabling cross-network play is beneficial. Farming Purified Essences often requires teamwork, especially when tackling certain dungeons and Helltide events. Having other players around improves the odds of encountering the specific bosses or events that drop essences.
Tip 3: Avoid Lairs of Lesser Evils
A common misconception is that you can farm Purified Essences by defeating Andariel, Duriel, or Belial in their traditional lairs (palaces or dungeons). This is not effective. The best farming spots are:
Undercity
Helltides
The Pit
Focusing on these locations will save time and significantly increase your efficiency.
Tip 4: Farm at Torment IV
Higher Torment levels improve drop chances for rare items. For Purified Essences, Torment IV is ideal. While the enemies are tougher, the improved rewards make it worthwhile. Always ensure your group composition and gear are optimized for this difficulty.
Tip 5: Farm One Purified Essence at a Time
Each Purified Essence has a different farming method, and attempting to farm multiple essences simultaneously often reduces efficiency. Let's break down how to farm each essence effectively.
Belial: The Easiest Purified Essence
Belial's Purified Essence drops reliably in the lower tiers of the Pit, specifically between Pit 72 and Pit 78. The reason for this exact range is unclear-some suggest it relates to dungeon level, others speculate it may be tied to group speed.
Solo or group play works, though soloing guarantees you reach the final boss.
Farming Belial at these tiers allows you to level up glyphs while pursuing the essence, maximizing your time efficiency.
Andariel: Solo or Group Tributes
For Andariel, there are two approaches:
1.Solo Tributes of Andariel: Guarantees Andariel appears at the end of the tribute run.
2.Group Undercity Tributes: Less predictable, as Andariel may not spawn at the end, but group farming is less tedious and more social.
Key tip: Never farm at the maximum cap of corrupted claws of Andariel, as this reduces drop chances. Managing your inventory is critical to increasing the odds.
Azmodan: Patience is Key
Azmodan's Purified Essence is simple but requires patience.
Go to Hawezar at Torment IV and wait for other players to continuously slay Azmodan.
Keep the game open to avoid being logged out.
Check periodically for the Purified Tongue on the ground.
Again, never farm while at the max cap of corrupted tongues; if you do, you must defeat Azmodan and open his chest to consume all tongues simultaneously.Duriel: The Most Challenging Purified Essence
Duriel requires careful preparation:
1.Summon Duriel with 2-3 Baneful Hearts. One heart is insufficient.
2.The Pained Altar at Helltides requires three Baneful Hearts to summon Duriel.
3.Location matters. Most players, including myself, found that the Dark Thicket in Scosglen has a higher drop rate for Duriel's Purified Horn. This is consistent across multiple players and attempts.
While the method seems specific and unusual, following these steps dramatically increases your odds compared to random farming in other zones.
Summary of Best Practices
To consolidate, here's a checklist for farming Purified Essences efficiently:
1.Never reach the corrupted essence cap. Consume or avoid picking them up to maintain maximum drop potential.
2.Do not carry Purified Essences with you. Offer them at their respective altars to keep the system active.
3.Enable cross-network play to leverage group farming advantages.
4.Avoid the lairs of lesser evils; focus on the Undercity, Helltides, and the Pit.
5.Farm at Torment IV for higher drop chances.
6.Farm one essence at a time, following tailored methods for each:
7.Belial: Pit 72-78
8.Andariel: Solo or group tributes
9.Azmodan: Hawezar, patiently wait
10.Duriel: Summon with 3 Baneful Hearts, farm Dark Thicket in Scosglen
By following these strategies, I was able to collect all Purified Essences twice in under 10 days. The system isn't entirely RNG; methodical farming and attention to mechanics can massively improve your chances.
Final Thoughts
Purified Essences are rare, valuable, and essential for both gameplay progression and spam in ****** 4. By understanding the mechanics of corrupted vs. purified drops, respecting inventory caps, and farming in the correct zones, you can reduce frustration and increase efficiency.
Remember, each essence has unique requirements and optimal farming strategies. There's no one-size-fits-all approach-careful planning, patience, and group coordination are key.
Following these tips will save time, reduce RNG frustration, and give you a reliable method to acquire all the essences you need. Whether you're a solo player or part of a group, this system works across different playstyles.
****** 4 Products For Sale on ***********, buy ****** 4 currency, items, accounts, skins, boosting service and more. 365/24/7 online and enjoy a quality service, make an order now.
****** 4: How to Farm Purified Essences Fast
- 239 Vistas
Último mensaje por abnerRRR
