u4gm What Makes Reliquarian Scion So Tempting in PoE 3 28 Mirage
Todo Sobre Calculadoras HP, Casio, Texas y demas programables. Comparte Tips y programas.
starmchaset
Estados Unidos
I didn't load up the 3.28 reveal to get hyped. It was more like background noise while I cleaned up my stash tabs and checked trade. Then the Reliquarian Scion popped up and I had that "wait, what?" moment. The idea of borrowing famous Unique-item notables without praying for drops is the first time a league-start Scion has felt genuinely practical, and it even changes how I think about early spending on POE1Currency when the first weekend economy gets weird.
Why Reliquarian Feels Different
Most Scion tweaks end up as polite options. This one looks like a toolbox. You pick from a curated set of Unique-inspired notables, so you can patch the exact hole your character has right now. Need stats to equip gems and gear? You can mimic that Astramentis-style attribute spike. Want that "my gloves are suddenly defensive tech" vibe? The Shaper's Touch-style conversion is right there. The clever part is the rotating pool each league, pulled from the last patch's meta. For Mirage, that rotation seems aimed at auras, resists, and smoothing out chaos pressure, which matters when the new content loves throwing surprise spikes at you.
Early Mapping Isn't About Damage, It's About Not Dying
People say "just cap res" like it's free. In the first 72 hours it's not. You're wearing whatever dropped, your flasks are scuffed, and you're still one bad roll away from a corpse run. Mirage's mirrored-map dives sound exactly like the kind of mechanic that punishes shaky gearing: you portal in, take risks, and if you stall you get swarmed. Reliquarian doesn't make you immortal, but it does make your build feel finished sooner. That's huge. You get to keep moving, keep mapping, and stop wasting time trying to fix three problems at once.
The PoB Numbers That Actually Matter
I spent way too long in PoB because the preview data is just tempting. A Righteous Fire setup using those attribute and conversion-style picks ends up with a chunky effective life pool without needing perfect rares, which is exactly what you want for yellow maps and awkward bosses. The bleed bow angle surprised me more: targeted bleed multipliers let the build hit real single-target damage early, the kind that ends Djinn fights before they turn into a panic spiral. Even minions look comfy if you lean into aura-style bonuses and defensive stacking, because minion builds don't need flashy gear, they need consistency.
My First-Weekend Plan
I'm going in with a simple loop: push atlas, chain Mirage runs, and take the Wish choices that keep maps flowing so I'm not stuck buying sustain. Reliquarian is basically my safety net while the market settles. And yeah, if someone hates the day-one wall, I get why they'd use u4gm to grab currency or items fast and jump straight to testing builds instead of spending hours in undergeared chaos.
Volver a “Calculadoras Programables”
