MMOexp Borderlands 4: Repairing the Second Monitor Device
Habla aqui sobre temas de mecanica de suelos e Ingenieria Geologica.
Stellaol
Australia
Once you've wrapped up One Gassy Issue, fast travel back to Borderlands 4 Boosting Lakeside Properties using the Sumpview Falls point you unlocked earlier. Speak with Beth, who explains that while the gas network is restored, the city's surveillance systems remain compromised. She's ready to work from her hidden basement lab, and that's where you come in.
Entering Beth's Lab
Beth directs you toward the bio-armored door leading into her lab. Just across from it sits a partially submerged locust gas dispenser. Before you can do anything, Creeps will ambush you—clear them out first.
Grab a gas canister from the dispenser and throw it at the armored door. The gas dissolves the bio-barrier, giving you access. Inside, more Creeps await—dispatch them quickly before focusing on Beth's equipment.
Beth instructs you to reboot her system using two switches. They're both encased in bio-armor, so grab canisters from the nearby dispenser to clear them. For the switch mounted higher at the back of the lab, toss the canister through the wall's opening rather than climbing up—otherwise the gas dissipates before you arrive. With both switches flipped, Beth notices one of her monitors is malfunctioning and sends you out to investigate.
Repairing the First Monitor Device
Head west from the lab until you spot a toppled antenna monitoring device marked on your HUD. Inspect it to learn it's been vandalized, with a critical part missing.
Beth quickly pings the part's location to the northwest, leading you to a Ripper camp. Among the enemies here is the thief responsible: THE SCRAPVENGER. Defeat him to recover the missing piece.
Return to the damaged monitor and slot the part back into place as soon as the system powers on, a wave of threshers bursts out of the ground. Defend the monitor and clear the enemies to complete the repair.
Beth now directs you to fetch a spare component for another device, but this time things aren't so simple. The part is stuck high up on a crane platform.
Make your way to the tower attached to the crane and climb upward. Once at the proper height, leap across to the hanging platform and open the container holding the part. With it in hand, travel to the second monitoring device west of your location.
When you arrive, a group of Creeps will swarm the area. Eliminate them, then toss a grenade to clear away the overgrowth wrapped around the machine. Place the spare part into the device, which triggers its reboot—except this time, something far nastier than ordinary Creeps responds.
Defeating the Omega Thresher
Beth warns you that the reboot has disturbed a notorious local beast: the Omega Thresher. She transmits coordinates to an arena-like area north of your location. Grapple into the enclosure and prepare for a boss fight.
The Omega Thresher isn't colossal, but its bio-armor makes it tricky. Luckily, you've already mastered the locust gas strategy. In the arena's back corner sits a gas dispenser. Grab canisters and lob them at the Thresher to cheap Borderlands 4 Boosting strip away its armor, leaving it vulnerable to gunfire. Repeat the process while dodging its heavy attacks until it finally goes down.
Volver a “Ingenieria de Mecanica de Suelos - Geologia”
