resolver probelma de etabs ultimate 22.06.6
Foro para hablar sobre los mensajes de error mas comunes en los programas y como solucionarlo
Si es sobre algún mensaje de error en el programa, entonces se recomienda que primero le apliques el ultimo parche, el cual tu distribuidor deberá proporcionarte.
Bece84
Honduras
Model has been checked, 36 warning messages
PISO 1F2 & F33 are too close. Check at (2050 3705 4700)
PISO 1F3 & F33 are too close. Check at (2050 2805 4700)
PISO 1F3 & F36 are too close. Check at (2050 2805 4700)
PISO 1F4 & F33 are too close. Check at (6820 2805 4700)
PISO 1F6 & F31 are too close. Check at (2050 6515 4700)
PISO 1F6 & F34 are too close. Check at (2050 6515 4700)
PISO 1F7 & F31 are too close. Check at (2050 5495 4700)
PISO 1F7 & F33 are too close. Check at (2050 5495 4700)
PISO 1F7 & F34 are too close. Check at (2050 5495 4700)
PISO 1F8 & F31 are too close. Check at (6820 5495 4700)
PISO 1F8 & F33 are too close. Check at (6820 5495 4700)
PISO 1F10 & F31 are too close. Check at (3320 5495 4700)
PISO 1F10 & F33 are too close. Check at (3320 5495 4700)
PISO 1F11 & F31 are too close. Check at (6820 7965 4700)
PISO 1F12 & F37 are too close. Check at (6820 12365 4700)
PISO 1F13 & F29 are too close. Check at (5820 12365 4700)
PISO 1F13 & F37 are too close. Check at (5820 12365 4700)
PISO 1F14 & F29 are too close. Check at (2050 12365 4700)
PISO 1F18 & F31 are too close. Check at (5995 5470 4700)
PISO 1F18 & F33 are too close. Check at (5995 5470 4700)
PISO 1F22 & F31 are too close. Check at (75 6490 4700)
PISO 1F23 & F29 are too close. Check at (75 9200 4700)
PISO 1F23 & F31 are too close. Check at (75 9200 4700)
PISO 1F24 & F31 are too close. Check at (1225 6515 4700)
PISO 1F24 & F34 are too close. Check at (1225 6515 4700)
PISO 1F25 & F34 are too close. Check at (1225 4595 4700)
PISO 1F26 & F33 are too close. Check at (2225 4595 4700)
PISO 1F26 & F34 are too close. Check at (2225 4595 4700)
PISO 1F5 & F29 are too close. Check at (75 12340 4700)
PISO 1F9 & F31 are too close. Check at (6995 9200 4700)
PISO 1F9 & F37 are too close. Check at (6995 9200 4700)
PISO 1F27 & F29 are too close. Check at (5995 9200 4700)
PISO 1F27 & F31 are too close. Check at (5995 9200 4700)
PISO 1F27 & F37 are too close. Check at (5995 9200 4700)
PISO 1F28 & F29 are too close. Check at (3345 9200 4700)
PISO 1F28 & F31 are too close. Check at (3345 9200 4700)
Check Selected Objects.
Volver a “Mensajes de Error CSI”
