Model has been checked, 36 warning messages
PISO 1F2 & F33 are too close. Check at (2050 3705 4700)
PISO 1F3 & F33 are too close. Check at (2050 2805 4700)
PISO 1F3 & F36 are too close. Check at (2050 2805 4700)
PISO 1F4 & F33 are too close. Check at (6820 2805 4700)
PISO 1F6 & F31 are too close. Check at (2050 6515 4700)
PISO 1F6 & F34 are too close. Check at (2050 6515 4700)
PISO 1F7 & F31 are too close. Check at (2050 5495 4700)
PISO 1F7 & F33 are too close. Check at (2050 5495 4700)
PISO 1F7 & F34 are too close. Check at (2050 5495 4700)
PISO 1F8 & F31 are too close. Check at (6820 5495 4700)
PISO 1F8 & F33 are too close. Check at (6820 5495 4700)
PISO 1F10 & F31 are too close. Check at (3320 5495 4700)
PISO 1F10 & F33 are too close. Check at (3320 5495 4700)
PISO 1F11 & F31 are too close. Check at (6820 7965 4700)
PISO 1F12 & F37 are too close. Check at (6820 12365 4700)
PISO 1F13 & F29 are too close. Check at (5820 12365 4700)
PISO 1F13 & F37 are too close. Check at (5820 12365 4700)
PISO 1F14 & F29 are too close. Check at (2050 12365 4700)
PISO 1F18 & F31 are too close. Check at (5995 5470 4700)
PISO 1F18 & F33 are too close. Check at (5995 5470 4700)
PISO 1F22 & F31 are too close. Check at (75 6490 4700)
PISO 1F23 & F29 are too close. Check at (75 9200 4700)
PISO 1F23 & F31 are too close. Check at (75 9200 4700)
PISO 1F24 & F31 are too close. Check at (1225 6515 4700)
PISO 1F24 & F34 are too close. Check at (1225 6515 4700)
PISO 1F25 & F34 are too close. Check at (1225 4595 4700)
PISO 1F26 & F33 are too close. Check at (2225 4595 4700)
PISO 1F26 & F34 are too close. Check at (2225 4595 4700)
PISO 1F5 & F29 are too close. Check at (75 12340 4700)
PISO 1F9 & F31 are too close. Check at (6995 9200 4700)
PISO 1F9 & F37 are too close. Check at (6995 9200 4700)
PISO 1F27 & F29 are too close. Check at (5995 9200 4700)
PISO 1F27 & F31 are too close. Check at (5995 9200 4700)
PISO 1F27 & F37 are too close. Check at (5995 9200 4700)
PISO 1F28 & F29 are too close. Check at (3345 9200 4700)
PISO 1F28 & F31 are too close. Check at (3345 9200 4700)
Check Selected Objects.
resolver probelma de etabs ultimate 22.06.6
- 12363 Vistas
Último mensaje por saulv1301
- 13365 Vistas
Último mensaje por sdaroch
- 10566 Vistas
Último mensaje por nand23321
- 11734 Vistas
- 14851 Vistas
