Alguien podrá apoyarme con algún ejemplo de análisis Pushover para marcos de acero en el programa RUAUMOKO?
Estoy trabajando un ejemplo, es un marco plano de acero a base de secciones tipo "W" pero al correr el programa obtengo resultados ilógicos, ya revise las propiedades de los materiales y al parecer todo está bien, y resulta que la estructura no colapsa.
Código: Seleccionar todo
FOUR STOREY SINGLE BAY TIMBER FRAME - Pushover Analysis
2 0 1 1 0 -1 0 0 0 0 ! Control Parameters
5 4 4 4 1 4 9.81 5.0 5.0 0.01 10.0 30.0 ! Frame and Time-history
0 5 10 3 1 10 0.7 0.1 ! Output and Plotting Options
0 0 ! Iteration Control
NODES
1 0.0 0.0 1 1 0 0 0 0 3
2 16.85 0.0 1 1 0 0 0 0 3
3 0.0 5.2
4 16.85 5.2 0 0 0 3 0 0 3
5 8.43 5.7 0 0 0 0 0 0 3
ELEMENTS
1 1 1 3
2 1 3 5 0 0 3
3 1 5 4 0 0 3
4 1 4 2 0 0 3
PROPS
1 FRAME
3 0 1 1 0 1 ! Parameters
2.05E8 7.9E7 2.28E-3 0.0 1.936E-8 1.75E-01 .325 0.325 0. 0. ! Elastic properties
0.0 0.03 0. 0. ! Bi-linear & Hinge
-12.04 -12.04 -15.12 15.12 ! Member loads
10000.0 -10000.0 40.0 -40.0 40.0 -40.0 ! Yield properties
0 0 20 20 20 20 ! Ultimate Ductilities
2 FRAME
1 0 0 0 0 0 ! Parameters
11.E6 0.733E6 0.075 0. 5.625E-4 2.0 ! Elastic Properties
3 FRAME
1 0 1 1 0 1 ! Parameters
11.E6 0.733E6 0.1 0.0 1.333E-3 5.651 .325 .325 0. 0. ! Elastic properties
4 FRAME
3 0 0 0 0 0 ! Parameters
2.05E8 7.9E7 2.28E-3 0.0 4.84E-7 6.54E-01 0.325 0.325 0 0 ! Elastic properties
WEIGHT
1 0.0 0.0
2 0.0 0.0
3 1.0 1.0
4 1.0 1.0
5 1.0 1.0
LOADS
3 0.0 -2.00 0.60
4 0.0 -2.00 0.60
5 0.0 -2.00 0.60
SHAPE ! NZ4203:1992 Equivalent Static Seismic forces
3 0.600 ! 0.92 of Base Shear distributed up the structure
! with a triangular distribution + 0.08 of the
! Base Shear at the top floor.
EQUAKE
1 1 1.0 1.0
START ! Linear Ramp Function 'Caltech' Format
1 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
2 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0
