Setup bridge, now I can't access Gargoyle
Para hablar solo de puentes.
Topic author
steviebradan
Reino Unido
#1
Vie Abr 27, 2018 5:21 am
Hi,
OK, I setup a bridge, and now I can't access gargoyle. I tried resetting the router with the reset button on the back of the WRT54GS, but nothing happened, except now the bridge doesn't work anymore.
My router, and the router I'm bridging to, all have different IP addresses. 192.168.1.1 and 192.168.0.1 respectively.
The only thing I changed on the bridging dialog screen is I selected the bridge to LAN checkbox so that I could use it wired instead of wireless. That seemed to work, other than the fact I could no longer access the router.
After I tried to use the hardware reset button, the router no longer bridges, so no internet anymore either.
It appears that DHCP no longer works on the wired connection either.
Any ideas?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
https://www.gargoyle-router.com/phpbb/v ... .php?t=176
Custom explainer video service
Thank you.
Vinculos Patrocinados:
Volver a “Puentes”
