GStarCAD - Programa de dibujo CAD económico y potente http://www.construaprende.com/ingsoftwa ... cad-mexico
Issue with tabs/bridges
Para hablar solo de puentes.
Topic author
steviebradan
Reino Unido
#1
Lun Abr 23, 2018 10:14 pm
Hi,
Tried to use tabs/bridges after update to 3.5 with 4mm thickness material.
First try with 5mm lenght 2mm thick and was not machined, the tabs was about 1mm thick.
Then tried to 5mm lenght 4mm thick (same as the material) and got the same: the bridges was very thin as before and sometimes not machined.
Last try with 3d tabs, 5mm lenght 2mm thick, I saw the 3d /\ into material but was really thin.
Exported to gcode archs mm.
Does anyone get a rule with suggested bridges lenght/thickness for material?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
http://forum.vectric.com/viewtopic.php? ... 13&p=88888
Product demo video production company
Thank you.
Vinculos Patrocinados:
Volver a “Puentes”
