DISEÑO DE ELEMENTOS TIPO SHELL EN SAP2000 V10
- joseluisyr
Saludos, alguien me puede decir donde se encuentra la opción para diseñar elementos tipo shell en sap2000 v10.
Hasta pronto.
Hasta pronto.
- joseluisyr
HOLA, ACLARANDO MI PREGUNTA ME REFERIA A LA OPCION PARA DISEÑAR EL REFUERZO, SEGUN SE DICE QUE UNA DE LAS VENTAJAS DE LA VERSION 10 ES QUE PERMITE VISUALIZAR EL REFUERZO DE ELEMENTOS SHELL. ALGUIEN SABE ALGO AL RESPECTO?joseluisyr escribió:Saludos, alguien me puede decir donde se encuentra la opción para diseñar elementos tipo shell en sap2000 v10.
Hasta pronto.
- jlramoscruz
Si asi es existe una opcion para el diseño y verificacion del refuerzo en placas y esta en la misma casilla de elementos SHELL.
- jlramoscruz
algunas imagenes
- jlramoscruz
buscandoen algunos foros encontre lo siguiente... espero aclare algunas dudas
ferroantunes (Civil/Environme) 5 May 06 10:09
I found this post from mgabrielle in a finite element analysis thread in this site. It might me interesting:
Here is a response from the the SAP2000 tech. support team:
The official documentation for concrete shell design implementation in SAP2000 is still under development and should be available soon. Meanwhile, here is some interim information on concrete shell design to keep you going.
The design of reinforcement for concrete shells in accordance with a predetermined field of moments, as implemented in SAP2000, is based on the following two papers:
Optimum design of reinforced concrete shells and slabs” by Troels Brondum-Nielsen, Technical University of Denmark, Report NR.R 1974
Design of Concrete Slabs for Transverse Shear”, Peter Marti, ACI Structural Journal, March-April 1990
Generally, the slab elements are subjected to eight stress resultants. In the SAP2000 terminology, these are: the three membrane force components F11, F22, and F12; the two flexural moment components M11, M22, and the twisting moment M12; the two transverse shear force components V13, and V23. For the purpose of design, the slab is conceived as comprising two outer layers centered on the mid-planes of the outer reinforcement layers and an uncracked core (this is sometimes called a "sandwich model"). The covers of the sandwich model (i.e. the outer layers) are assumed to carry moments and membrane forces while the transverse shear forces are assigned to the core. The design implementation in SAP2000 assumes that there are no diagonal cracks in the core. In such a case, a state of pure shear developes within the core, and hence the transverse shear force at a section has no effect on the in-plane forces in the sandwich covers. Thus, no transverse reinforcement needs to be provided, and the in-plane reinforcement is not enhanced to account for transverse shear.
Given below is a summary of the procedure as implemented in SAP2000:
1. As mentioned above, the slab is conceived as comprising two outer layers centered on the mid planes of the outer reinforcement layers
2. The thickness of each layer is taken as equal to the lesser of:
- twice the cover measured to the center of the outer reinforcement
- twice the distance from the center of the slab to the center of outer reinforcement
3. The six resultants F11, F22, F12, M11, M22, and M22 are resolved into pure membrane forces N11, N22, and N12 calculated as acting respectively within the central plane of the top and bottom reinforcement layers. In transforming the moments into forces, the
lever arm is taken as the distance between the outer reinforcement layers.
4. For each layer, the reinforcement NDes1, NDes2, concrete principal compressive forces Fc1, Fc2, and concrete principal compressive stresses Sc1 and Sc2, are calculated according to the rules set out in Reference 1 above.
5. Reinforcement forces are converted to areas per unit width (i.e. reinforcement intensities) Ast1, and Ast2 using appropriate steel stress and stress reduction factor.
You can use this feature to estimate the reinforcement requirements for a concrete shell element used in any model. As is evident from the above discussions, the design is solely based on element stress resultants obtained from a finite element analysis. No effect of the boundary conditions is directly used in the design routines.
Ricardo
Ricardo
Seee.... sería ótimo
Oye oswalarce.....
Una apreciación personal tal vez me equivoque.........
Parece que te inicias en el manejo de los elementos SHELLS por el tipo de preguntas, lo deduzco por que las mismas he venido haciendo desde hace 3 años a mis colegas..........
Te diré que aún el más avanzado estudioso del tema siempre tendrá por delante un universo de cosas por aprender......
Acuérdate del sabio filósofo que dijo: "A mi edad y después de todo lo visto y aprendido, yo solo sé que no se nada" creo que fué Sócrates.....
Ahora un recomendación......
De tal suerte que vamos pa delante, te recomiendo que visites el foro de SAP2000 allí hay un tema bastante ilustrativo y trata de la interpretación de las salidas que el SAP reporta para los SHELLS recomiendo ampliamente los documentos que allí están disponibles para descargar te darán mucha luz.......
No dudo lo hayan hecho perp lo recomiendo por si las de hule:
En la ayuda del SAP si se teclea el buscador de la ayuda lo siguiente:
Shell Element Internal Forces/Stresses Output Convention
Desplegará una información relacionada con las salidas para SHELLS si en ese contenido buscan y teclean la liga:
entonces será mostrado una definición de cada salida, en la versión 10 inclusive aparecem figuras esquemáticas de tales salidas....
Lo recomiendo
Lo recomiendo
Amigo,
Por favor podrias ser un poco mas preciso y mencionar exactamente a cual hilo del foro te refieres?
Gracias.
Hasta Pronto
Gracias.
Hasta Pronto
ach escribió:Oye oswalarce.....
Estimado kaokao1...
La dirección del foro es la siguiente:
http://foros.construaprende.com/siguien ... c&start=10
Saludos....
Saludos....
- chrismend2000
HOLA, RETOMANDO EL TEMA DE DISEÑO DE PLACAS DE CONCRETO...ESPECIFICAMENTE DE LOS DENOMINADOS "MUROS DE CORTANTE".....PARTICULARMENTE LO INTERPRETO DE LA SIGUIENTE MANERA:
1.-PARA UN DISEÑO CONVENCIONAL..SE PREDIMENSIONA EL ACERO QUE REQUIERE EL MURO PARA LA ZONA "EN TRACCIÓN", EL MISMO QUE SE REDISTRIBUYE A LO LARGO DE ESA MITAD EN TRACCIÓN...PREPONDERANTEMENTE EN EL NÚCLEO CONFINADO PARA AUNMENTAR EL BRAZO DE PALANCA DEL REFUERZO. CON RESPECTO AL CENTROIDE PLASTICO. TAL ES ASÍ QUE PARA LA PARTE FUERA DEL NUCLEO CONFINADO, LA CUANTIA DE ACERO ES RELATIVAMENTE MENOR.
SE REALIZA EL DIAGRAMA DE INTERACCIÓN CORRESPONDIENTE Y SE COMPARA EL Mu Y EL Pu....OPTIMIZANDO POR REPETICIÓN DE LA INTERACCIÓN, EL DISEÑO DEL MURO...
2.-CUANDO SE OBTIENEN LOS RESULTADOS DEL DISEÑO DE ACERO DEL SAP2000V10, EN UNIDADES ´METRICAS, ESTOS APARECEN EN CM2/CM PARA CADA CARA; Y SE NOTA UNA REPARTICIÓN BASTANTE CERCANA A LA DESCRITA EN EL ITEM 1, EN DONDE LA CONCENTRACIÓN DE CUANTÍA DE ACERO VERTICAL SE DÁ EN LOS EXTREMOS Y EN EL CENTRO APARECE MARCADAMENTE MENOR; OCURRIENDO ANÁLOGAMENTE CON EL ACERO HORIZONTAL. (DIVIDIENDO AREAS SHELL EN EL MODELO).
3.-LO ANTERIOR IMPLICA, QUE LOS RESULTADOS DE REQUERIMIENTO DE ACERO SE PUEDEN LEER A LO LARGO DEL MURO DE CONCRETO; Y QUE PARA MEJORAR EL DISEÑO SE DEBERÍA PLANTEAR EL ACERO A COLOCAR Y CHEQUEAR LA DISPOSICIÓN.
BUENO...ESPERO CON ESTO REABRIR EL TEMA PARA MEJORAR EL CONOCIMIENTO DEL MISMO.
ATTE.
ATTE.
- diegocivil
Esto es fabuloso. Pero como accedo a las ventanas mostradas en las figuras?oswalarce escribió:PRIMERO GRACIAS ESTA MUY CLARO LA EXPLICACION CON LAS IMAGENES. uNA cONCULTA Como interpreto los datos en las graficas si ya he modelado el elemento shell. Mil Gracias
GRacias
Cordial sudo
Agrdeceria ayuda para modelar edicios de mamposteria estructural y o alcantarillas cajon mediante shells y algo sobre el uso de constrains.
Si puderas enviarme unos modelitos en sap o en etabs....para estudiarlos, ok.
se te edito el.correo por reglas del foro
- PedroHMC
Saludos...
Alguien sabe si se pueden sacar los resultados del diseño de losas en tablas, porque yo no encontré esa opción... en los resultados, solo se muesta el gráfico en código de colores y los valores respectivos en (área/longitud de ancho) y nada más...
Tal vez no probé de la forma correcta, si alguien sabe por favor ayúdeme con eso...
BUENAS CON TODOS QUISIERA ME PUDIERAN ABSOLVER UNA DUDA SOY RECIEN USUARIO DEL PROGRAMA SAP2000 VERSION 11 Y BUENO MI DUDA ES CON RESPECTO AL COMANDO MESH, PENSABA QUE ES IGUAL AL COMANDO DIVIDE AREAS, JUSTO ESTOY TRABAJANDO CON UN SISTEMA DE TECHO DE LOSA MACIZA Y VIGA PARA UN TANQUE ENTERRADO Y BUENO NOSE SI SE TIENE Q COLOCAR NECESARIAMENTE EL COMANDO MESH SI ES QUE YA E DIVIDIDO MI LOSA CON EL COMANDO DIVIDE AREAS, WENO NOSE SI ME PODRIAN POR FAVOR ACLARAR LA FUNCION ESPECIFICA DEL COMANDO MESH. MUCHAS GRACIAS DE ANTEMANO.
Hola amigos, si desean mayor información sobre este tema ta vez este link les puede ayudar son videos de CSI y el tema que presenta es el de Nonlinear Shear Walls (30 min) porque justo ahora estoy diseñando un deposito de relaves y lo quiero proyectar de concreto armado asi que si tienen algo que sume pues bienvenido sea. me pueden escribir a xxxxx Les dejo el link para que se lo bajen todito.
http://www.csiberkeley.com/Support_WL_SAP.html
se te edito el.correo por reglas del.foro
hay forma de regular el refuerzo, de tal forma que se pueda modelar mamp estructural
Buenos dias, me encuentro modelando un edif en concreto armado con el sap 2000 v14.0.0 en el cual las losas son del tipo nervada en una y dos direcciones , quisiera saber como hacerlo en mi modelo,o si debo colocar un elemento tipo menbrana y coloco el peso de la losa como una caga permanente.
- jcoronellr
Saludos lianyer
En este foro existe mucha informacion, solo es tomarse el tiempo y buscarla. bueno te dejoe ste link del mismo foro, espero te ayude.
modelamiento-en-sap2000-de-un-edificio- ... 12749.html
Ing. Jaime
Ing. Jaime
tienes que seleccionar los nodos y los elementos tipo áreas que desees analizar luego te vas a tablas y luego lo exportas a excelPedroHMC escribió: ↑Jue Jul 03, 2008 4:49 am Saludos...
hola una consulta al querer dirigirme a estas direcciones me sale mensaje como este:"No route found for "GET /siguiente-vt3834.html" (from "viewtopic.php?f=24&t=1106")"ach escribió: ↑Jue Nov 01, 2007 1:19 pm Estimado kaokao1...
Saludos....
porque ocurre esto, es por la antiguedad del enlace?
es porque se ha borrado la ruta o del servidorkuky2008 escribió: ↑Mié May 23, 2018 7:15 amhola una consulta al querer dirigirme a estas direcciones me sale mensaje como este:"No route found for "GET /siguiente-vt3834.html" (from "viewtopic.php?f=24&t=1106")"ach escribió: ↑Jue Nov 01, 2007 1:19 pm Estimado kaokao1...
Saludos....
Hola buenas tardes, tengo la losa ya definida como elemento área y ahora deseo ver sus ejes locales . Voy a set display options y doy click a local axes , sin embargo, no los muestra , que debo hacer ? Gracias de antemano
una de las causas es por que la estructura esta extrudida, quita esa opción y se resolvería
- 2 Respuestas
- 2554 Vistas
- 716 Vistas
Último mensaje por llastra
- 2 Respuestas
- 1071 Vistas
Último mensaje por Vic-11
- 1999 Vistas
- 1994 Vistas
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 51 invitados
